Hello
Just to be sure
If i buy a Airwave 25
But my enviroment grows 100 more APS for example
I just need to buy more licenses(maybe upgrade the server cpu ram etc) and consolidate my airwave license right?
Cheers
Carlos
Correct. You can have TAC merge them or you can do it on the licensing site.
In the upcoming AirWave 8, you'll be able to add multiple license keys.
Thanks Mr. Cappli :)
And when AirWave 8.0 is released licenses will be additive! :smileyvery-happy:
Doh...........I just noticed that Cappalli already stated that.
Scaling will be limited by the hardware as specified in the "Hardware Sizing Guide". NOTE: The AirWave 8.0 Sizing Guide has not been published yet but will be by launch.
Hello marcus
What means
That is referencing SSD (Solid State Drive) hard-drives.
so it cannot grow more than 5000 APS in one airwave?
I know i can have many airwave and a master console but mmm in one airewave the limit is 5000 then?
That is the limit for a single box. The limits will be increased with AirWave 8.0............stay tuned.
how cai i view hoy many licenses i have installed on my AWS server?
After you login to AirWave, on the 'Home' page, there is a license link towards the right. From there, it will show you how many devices are in the license that is installed.
