Network Management
Airwave login failures
  • 1.  Airwave login failures
    Posted Dec 24, 2013 12:17 PM
    Hi All,
    Where would we be able to find a log showing failed login attempts to the Airwave server (via the web interface)?
    Example, user John.Doe has an account but types in the wrong password.
    Thanks much!
  • 2.  RE: Airwave login failures
    Posted Dec 24, 2013 06:25 PM
    If you ssh to the server you can tail /var/log/httpd/access_log and look for the pattern. I think the login messages all have "LOGIN" in them.
    cat /var/log/httpd/access_log* | grep LOGIN | grep  "24/Dec/2013"
    will show you all logins for today.
  • 3.  RE: Airwave login failures
    Posted Dec 27, 2013 10:19 AM
    Hi!
    Thank you for the info for successful logins.
    I figured out that I had to further search for the "403" error for an unsuccessful login.
     cat /var/log/httpd/access_log* | grep LOGIN | grep "403"
    Happy New Year!
