Network Management
Airwave management authentication using radius server
  • 1.  Airwave management authentication using radius server
    Posted Jan 06, 2014 01:20 PM
    Hi Everyone,
    I have a query regarding the management authentication for the administrator for Airwave using windows Radius server.
    We have configured the NPS (win 2008) server and also configured the Radius server on the airwave by navigating to AMP setup - > Authentication.
    Authentication is working fine using PAP but we require the authentication to use MSCHAPv2.
    Do we have to enable on the Airwave in order to the Airwave to use the MSCHAPv2 as a authentication protocol for authenticating the management users instead of PAP?
    Thanks in advance.
  • 2.  RE: Airwave management authentication using radius server
    Posted Jan 06, 2014 05:33 PM
    I don't believe this is supported...
  • 3.  RE: Airwave management authentication using radius server
    Posted Jan 06, 2014 06:41 PM
    Hi SethFiermonti,
    Thank you for your reply.
    So you mean we cannot use MSCHAPv2 or any other authentication protocol for authenticating Airwave management access if we use Radius server? So only PAP is used between the Airwave and Radius server for authenticating?
    Do we have this feature in future relase?
    Thanks again.
  • 4.  RE: Airwave management authentication using radius server
    Posted May 12, 2014 12:37 PM
    I made an RFE in the ideas portal.
    Promote it if you'd like
    https://arubanetworkskb.secure.force.com/prm/ideas/viewIdea.apexp?id=08740000000LFFH
  • 5.  RE: Airwave management authentication using radius server
