Network Management
Airwave Master Console - installation on virtual environment
  • 1.  Airwave Master Console - installation on virtual environment
    Posted Sep 22, 2017 05:16 PM
    Hi Community:
    I am planning to deploy a Master Console on a virtual enviroment and I have these questions:
    Could you help me with the characteristics of a virtual machine to install Airwave Master Console and the percentage of partitions used on it?
    What is the main goal of the storage on the Master Console? I think all monitoring data and reports are stored on AMPs
    is it possible to start with a certain amount of storage to this server and after increase the resources? or maybe create a different partition for a different partition of the aruba.
    Regards
    Carlos Contreras
  • 2.  RE: Airwave Master Console - installation on virtual environment
    Posted Sep 28, 2017 06:49 PM
    Any Help about this topic?
  • 3.  RE: Airwave Master Console - installation on virtual environment
    Posted Sep 28, 2017 09:23 PM
    Below is a snapshot from hardware sizing guide for the master console.
    Most virtualized environments use a shared disk subsystem assuming that each application will have bursts of I/O without a sustained high I/O throughput. AirWave requires a continuous sustained high data I/O rate.
    Note: Arubarecommends a 20% increase buffer for virtual environments. Ensure you allocate enough extra disk spacefor the OS and swap when partitioning the virtual disk.
  • 4.  RE: Airwave Master Console - installation on virtual environment
    Posted Sep 29, 2017 12:56 PM
    Hi Vishnu
    Thank you for your answer, do you know how the partitions are structured in an Airwave Master Console and what is the pourpose of the storage in Master Console?
  • 5.  RE: Airwave Master Console - installation on virtual environment
    Posted Oct 11, 2017 02:33 PM
    /root = OS & AirWave codebase
    /usr = running code
    /var = logs, database (includes reports), graphs, and backups
    -- MC compiles data collected from watched AMPs for summary view
    -- MC reports will either go off local MC db or be pulled from the watched AMPs depending on the data granularity of the report
    Ideally, it will be installed as a single partition, but if you must pull a partition off server - it should be the /var partition which usage varies based on number of watched AMPs and number of reports (and frequency reports are run).
