Airwave "Match Reports" are empty
  • 1.  Airwave "Match Reports" are empty
    Posted Mar 13, 2014 09:17 AM
    We have Client Match enabled for several customers and were hoping to get Match event reports out of Airwave for these customers however the reports are always empty. Is this something that is supposed to work with Aruba Instant ?
    Running Firmware 4.0.0.3 on RAP-109's & AMP 7.7.9
    Serge
  • 2.  RE: Airwave "Match Reports" are empty
    Posted Mar 13, 2014 01:07 PM
    Client Match is part of the IAP 4.x stream of IAP code  and 4.x is part of the supported fetures under Airwave 7.7.9. If you are not seeing them - could be an optical bug. There were a few identifiied defects in Airwave 7.7.9 relative to client match, but I'd get validated by TAC.
    Adam
