Network Management
AirWave MIBs
  • 1.  AirWave MIBs
    Posted Feb 21, 2014 05:19 AM
    I was looking for MIB guide for AirWave but with no luck.
    AirWave is sending specific to him OIDs i.e.. 1.3.6.1.4.1.12028.. and I would like to get some more details about them.
    Does anyone came across that guide ?
  • 2.  RE: AirWave MIBs
    Posted Feb 21, 2014 09:52 AM
    Are you seeing this in the trap logs?  Are they coming in from devices or is Airwave itself sending them?
  • 3.  RE: AirWave MIBs
    Posted Feb 24, 2014 03:38 AM
    We see it coming in to our trap server.
    And they come with source IP of AirWave.
    For example 1.3.6.1.4.1.12028.4.xxx is specific to Instant AP.
  • 4.  RE: AirWave MIBs
    Posted Feb 24, 2014 02:36 PM
    This request would get better traction by opening a support case.
  • 5.  RE: AirWave MIBs
    Posted Feb 25, 2014 08:23 AM
    Rob is correct.
    Can you post a specific trap you are getting and maybe we can help.
    For example 1.3.6.1.4.1.12028.4.15 is the following trap
  • 6.  RE: AirWave MIBs
    Posted Feb 25, 2014 09:21 AM
    I was hoping you can direct me to the file you are using in the mib browser from the screenshot.
    There are few traps we are getting plus it would be nice to have it for future reference.
    Do I need to open a case to get it ?
  • 7.  RE: AirWave MIBs
    Posted Feb 25, 2014 09:32 AM
    @pmonardo uses a 3rd party mib crawler tool against the aruba mibs.  If you don't want to use a 3rd party app, you could just take the oid and run it against the internal translation scripts on the AMP like so:
    [root@amp mibs]# oidtranslate 1.3.6.1.4.1.12028.4.15
    AWAMP-MIB::awampEvent
    [root@amp mibs]# oidinfo 1.3.6.1.4.1.12028.4.15
    awampEvent OBJECT-TYPE
    -- FROM AWAMP-MIB
    ::= { iso(1) org(3) dod(6) internet(1) private(4) enterprises(1) airwave(12028) awamp(4) 15 }
    Some of the mibs may be harder to define from just viewing in the mibs, which is why I suggested checking with support.
