Network Management
airwave mismatch cert-psk
This thread has been viewed 22 times
  • 1.  airwave mismatch cert-psk
    Posted Jan 13, 2022 01:11 PM
    i've upgraded some iap's from 6.5.2 to 6.5.4 and now get a mismatch in the config.  The mismatch is :
    cert-psk xxxxxxxx
    Performing 'apply-all' to the mismatch does not solve anything.  The mismatch just returns.
    I've logged into one iap and executed the 'cert-psk' command.  And am getting a parse error.  So i suspect this command no longer exists in 6.5.4.
    The question is where is this coming from?  And how to get rid of it?
  • 2.  RE: airwave mismatch cert-psk
    MVP GURU
    Posted Jan 13, 2022 02:26 PM
    What Airwave release ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: airwave mismatch cert-psk
    Posted Jan 14, 2022 02:49 AM
    8.2.13.0
    Peter Nobels
  • 4.  RE: airwave mismatch cert-psk
    Posted Jan 14, 2022 04:37 AM
    i was able to reproduce this in a lab setup...
    The cert-psk comes with an installed cert.  The cert itself was expired.  Not sure if the issue comes from that fact.  But once i pointed the group to a valid cert the mismatch was resolved.
  • 5.  RE: airwave mismatch cert-psk
    MVP GURU
    Posted Jan 14, 2022 06:51 AM
    Yes, Airwave can't install an expired certificate...
