Network Management
Airwave- modify VLAN
This thread has been viewed 40 times
  • 1.  Airwave- modify VLAN
    Posted Jan 19, 2022 04:47 AM
    I wanted to ask you for help regarding how I can modify the assignment of a vlan in a port with Airwave. Something as simple as in IMC.
    Thanks a lot.
    Nacho Marin
  • 2.  RE: Airwave- modify VLAN
    MVP EXPERT
    Posted Jan 19, 2022 05:02 AM
    Is this an IAP or a Switch managed via AirWave?
    Craig Syme
  • 3.  RE: Airwave- modify VLAN
    Posted Jan 19, 2022 06:04 AM
    Nacho Marin
  • 4.  RE: Airwave- modify VLAN
    Posted Jan 20, 2022 04:06 AM
    What type of switch? And do you have it in managed (read-write) mode in Airwave? In GUI config? Template config?
    May be good to work with your Aruba partner or Aruba support, as there are multiple ways of doing this, depending on what type of device and how it is managed. Shouldn't be too hard, but if someone shows you how to do it, it is probably more effective.
  • 5.  RE: Airwave- modify VLAN
    Posted Jan 21, 2022 02:04 AM
    For example on an Aruba 2930F. Through the GUI configuration. In IMC, you can access a switch, one of its ports,
    Interface Management -> Modify VLAN and directly change the configuration.
    Isn't there such a way to proceed in an Aruba switch from Airwave?
    Nacho Marin
  • 6.  RE: Airwave- modify VLAN
    Posted Jan 21, 2022 08:20 AM
    Nacho,
    Yes, we have option to make VLAN config changes from Airwave, check under Devices section in Airwave, there should be option to modify switch interface.
    Pavan Arshewar
    Principal Network Engineer
    If my post addresses your query, give kudos!
  • 7.  RE: Airwave- modify VLAN
    Posted Jan 25, 2022 10:25 AM
    This is what it shows me but I can't see it.
    Nacho Marin
  • 8.  RE: Airwave- modify VLAN
    Posted Feb 03, 2022 06:57 AM
    Could I not see that action because the switch is in administration mode: "Monitor Only + Firmware Upgrades"?
    Nacho Marin
  • 9.  RE: Airwave- modify VLAN
    Posted Feb 04, 2022 11:44 AM
    Right. The switch should be in manage mode to push config changes. However, before placing the switch in manage mode, make sure there are no mismatches. Airwave will push the config what it has in the group.  This can lead to config being removed from switch. So, do an import of switch config first to make sure the config is good. Then place the switch in Manage mode to push further changes.
    Support can help if you need this to be done carefully.
    Gowri Sankar Amujuri
  • 10.  RE: Airwave- modify VLAN
    Posted Feb 07, 2022 02:36 AM
    Thanks!
    Nacho Marin
