Network Management
Airwave monitoring client's bandwidth usage
  • 1.  Airwave monitoring client's bandwidth usage
    Posted Jun 12, 2017 06:40 AM
    Hi community,
    i'm trying to use Airwave 8.2.3.1 to monitoring a network, based on IAP and hp switches, all added and installed.
    The goal is to know when a client and which cilent is saturating/using too much network, but i can see only AP's usage not clients.
    I'll need it on real time so... no reports.
    There is a function that i missed? Or have any ideas?
    If i can ask a second thing, i have switches which have lan clients, i can see "neighbors" and "connected devices" correctly, but can't see any client.
  • 2.  RE: Airwave monitoring client's bandwidth usage
    Posted Jun 12, 2017 06:47 AM
    We could either create a custom view in clients>connected page to see the client usage section or set a client usage trigger from system>trigger page.
    Regarding HP switch clients not showing in Airwave , may i now the model/firmware version?
    Pavan
  • 3.  RE: Airwave monitoring client's bandwidth usage
    Posted Jun 12, 2017 08:25 AM
    Hi Pavan,
    on clients>connected is very useful, i searched it on "All" and there isn't a "usage" section, but can't be sort for usage? I can use a trigget to alert then going to "connected" and see who, but if i can sort for usage will be more easy to view.
    Switches are:
    HP J8770A 4204vl
    HP J9022A 2810-48g
    HP J9028B v1800-24g
    HP J9776A 2530-24g
    HP J9728A 2920-48g
    HP J9853A 2530-48g
    firmware is the latest updated on april (i can't reach them in this moment for write the exact name).
  • 4.  RE: Airwave monitoring client's bandwidth usage
    Posted Jun 12, 2017 12:33 PM
    It is avaiable in client>connected pag, click on Arrow, it will ist New View option , click on this to create custom view.
    Attached latest support device, guide, it looks we does not have complete support for the listed version.
    Pavan
    Attachment(s)
  • 5.  RE: Airwave monitoring client's bandwidth usage
    Posted Jun 13, 2017 03:46 AM
    What i meant is that i can't sort/order the view based on usage, but i use a trigger to alert when a client go over a certain usage.
    Ok then i can't see lan client because switches aren't supported.
    Thanks for help
  • 6.  RE: Airwave monitoring client's bandwidth usage
    Posted Jun 13, 2017 10:36 AM
    For switches there is something to do?
    Cause my customer want a total control, if Airwave can't control lan clients he'll leave this project.
    Portal for request a features redirect to HPE, and is now available at the moment.
    edit: i have to open another topic or i can use this?
  • 7.  RE: Airwave monitoring client's bandwidth usage
    Posted Jun 13, 2017 11:30 AM
    I would recommand to file feature request and follow up with your accounts team for update.
    If you have any different queries, please open new topic.
    Pavan
  • 8.  RE: Airwave monitoring client's bandwidth usage
    Posted Sep 24, 2017 07:08 AM
    HI,
    Sorry I have to reply to this post because:
    1. Can you provide a direction for us to create new POST/Questions?
  • 9.  RE: Airwave monitoring client's bandwidth usage
    Posted Sep 25, 2017 02:21 AM
    Hi Borely,
    starting from the home page of community, click here;
    go to discuss, then select a category and now you'll see a "Start a topic" orange button.
  • 10.  RE: Airwave monitoring client's bandwidth usage
    Posted May 07, 2019 11:59 AM
    Did you get a means of doing this?
