Network Management
Airwave move IAP cluster to another group
  • 1.  Airwave move IAP cluster to another group
    Posted Jul 11, 2022 03:13 AM
    We are using a local Airwave server to manage 5 IAP clusters dispatched across 5 sites.
    All these clusters are in the same Airwave group (default group) and used firmware version 6.5.x.x
    We plan to increase IAP number in one of these cluster, but new IAP will be in 8.1.X.X version without possibility to downgrade. So if i correctly understood the cluster must be first in 8.1.X.X version before being able to add new IAP 8.1.X.X
    I'm not sure at all of the way to increase a cluster firmware but i think we'll need first to move this cluster into a different group to be able to upgrade it.
    If someone could point me to a documentation describing the process to move from default group to another group it would be very helpful.
    Thanks in advance
    Olivier
  • 2.  RE: Airwave move IAP cluster to another group
    Posted Jul 11, 2022 09:34 AM
    Hi Olivier,
    Are you managing IAP from Airwave with template or IGC? or are the IAP's in Monitor only mode?
    There are few ways to achieve the upgrade. Yes, the cluster should be in 8.x before joining new IAP with 8.x code.
    Better approach can be with new group in Airwave.
    Set the new group version to desired 8.x version.
    Make sure the template (if template config is done) is copied from old group to new group and make any modifications to make it as 8.x template. Then move the desired cluster to new group so that it gets upgraded to 8.x and have the config. Mismatches can be present which needs to be solved.
     or If IGC is used, move the desired cluster to new group so that IGC imports the config from IAP on 6.x and then proceed with setting the f/w to 8.x on new group.
    Regards
    Gowri Amujuri
  • 3.  RE: Airwave move IAP cluster to another group
    Posted Jul 11, 2022 11:13 AM
    Hi Gowri,
    Many thanks for your reply.
    We are using IGC, i'll test your suggestion methode and let you know.
    regards,
    Olivier
  • 4.  RE: Airwave move IAP cluster to another group
    Posted Jul 13, 2022 09:56 AM
    Hi Gowri,
    I folowed your instructions :
    - Created a new group with IGC enabled
    - move the current 6.5.x.x cluster into this new group
    - upload firware 8.10.X into my ariwave server
    -  scheluded a firmware update
    Update has been done, i can see IAP with 8.10 firmware but i can see a state "configuration error" in Airwave (device - list). If i tried to update cluster setup (group - instant config)
    what i did wrong ?
    Is there another operation to make this group V8.10 compatible ?
    Thanks in advance for your help.
    Olivier
  • 5.  RE: Airwave move IAP cluster to another group
    Posted Jul 13, 2022 10:49 AM
    Olivier, in the new group is IGC version set to 8.10?
    Regards
    Gowri Amujuri
  • 6.  RE: Airwave move IAP cluster to another group
    Posted Jul 13, 2022 10:54 AM
    Hi Gowri,
    No, i saw (too late) that only 8.7 is available on my airwave server.
    I tried to download Airwave upgrade but no way to find upgrade file. I have many airwave licences but the ASP say i don't have airwave licences.
    It makes me crazy.
    regards,
    Olivier
  • 7.  RE: Airwave move IAP cluster to another group
    Posted Jul 13, 2022 11:00 AM
    Hi Olivier,
    May be some miss. Please call Airwave TAC, they will check and provide you upgrade image.
    Regards
    Gowri Amujuri
