Network Management
Airwave: Need to export 2. radio Mac & Floor plan string
  • 1.  Airwave: Need to export 2. radio Mac & Floor plan string
    Posted Jun 21, 2022 11:06 AM
    Hey All
    I'm in need of exporting device ID + Floor plan + 2nd Radio MAC Address.
    I can get a report from airwave that generates device ID (name) + 2nd Radio MAC Address by simply making a custom report with inventory --> devices. Is there another field I can add to get this data?
    We have around 12k+ AP's (yes) and will eventually need this data on all AP's - so doing this manually is not an option.
    Any suggestions, maybe I have to go directly on the controller, in that case - pls describe the workflow?
    Regards
    Judson
  • 2.  RE: Airwave: Need to export 2. radio Mac & Floor plan string
    Posted Jun 21, 2022 11:17 AM
    If the AP's are placed on VisualRF, there are 2 options:
    1. In the AP list page, select the columns for data you need + location which will show where the AP is placed. you can do a CSV export of the list page.
    2. In the inventory report, select location column to get the same data.
  • 3.  RE: Airwave: Need to export 2. radio Mac & Floor plan string
    Posted Jun 22, 2022 02:28 AM
    1. i'm not able to choose the '2ND RADIO MAC ADDRESS' in the list witch is the one I need. usually it shows the 2,4 Ghz radio Mac and not the 5 Ghz.
    2. nope it will show the what I believe is the SNMP location. not the  VisualRF location?
  • 4.  RE: Airwave: Need to export 2. radio Mac & Floor plan string
    Posted Jun 22, 2022 09:27 AM
    1. First or second Radio depends on what was set on the AP initially. So the 2nd Radio need not be necessarily 2.4GHz. Irrespective of the band, i believe the Radio MAC doesn't change.
    2. Location in AirWave is VisualRF location and not syslocation of AP.
  • 5.  RE: Airwave: Need to export 2. radio Mac & Floor plan string
    Posted Jun 30, 2022 12:49 AM
    well i'm not getting the VisualRF location and the 5GHz mac do you know of a way to pull out the data from the CLI?
  • 6.  RE: Airwave: Need to export 2. radio Mac & Floor plan string
    Posted Jun 30, 2022 09:23 AM
    We cannot get from CLI as CLI is locked. If the VisualRF location is not present in UI, it wont be present in CLI too. It may be good to open a TAC case to see why the clients doesn't show VisualRF location. Probable reason can be - client is not heard by atleast 3 AP's for triangulation and location of the same.
