It looks like our problem was the result of a poor setting in AMP Setup>General>Performance
Originally for this server the processes was set to 3. On our other 2 AW it is set to 15.
This setting was generating errors on the System>Performance page (which I hadn't looked at, could have saved myself a lot of time here, no idea why/how it got set to 3)
After this the server had to rebooted as it dropped and didn't recapture any data from the controllers. After a reboot, and giving some time for polling, we ended up with clients being reported and usage being recorded where previously we only saw '0'.
We finally have Glass pretty much in line with the MC now, reporting almost accurately for each of the 3 clusters. I guess the variance with the MC is now down to Glass polling the AW instances.
We still have problems with this AW server (link up link down 16386 alerts being generated) but clients and usage appears fixed.
Nathan
Original Message:
Sent: May 15, 2023 11:51 AM
Subject: Airwave not reporting traffic
I seem to be having very similar issues, recently abandoned our older AW server, and upgraded TWO NEW servers to the new AW 8.3.0 'redhat' version. It appears all the devices (controllers and APs) seen in both AW servers, but I am not seeing any information on client devices.
Original Message:
Sent: May 09, 2023 05:51 AM
I recently moved a couple of controllers out of one cluster and into another to balance requirements. The relevant Airwave instance is refusing to show clients or traffic from the moved controllers. I've picked over config on each moved controller to check that SNMP and MON receiver settings are correct/updated after the move (including SNMPv3 username and passwd on both Controllers and AW), but I'm failing to see where the problem is. Airwave is reflecting the APs on each controller, but that's all.
Anyone got an idea what I've missed?
Thanks.
Nathan
