Aruba Airwave
last person joined: 12 days ago
Airwave not reporting traffic
This thread has been viewed 23 times
  • 1.  Airwave not reporting traffic
    Posted May 09, 2023 05:51 AM
    I recently moved a couple of controllers out of one cluster and into another to balance requirements. The relevant Airwave instance is refusing to show clients or traffic from the moved controllers. I've picked over config on each moved controller  to check that SNMP and MON receiver settings are correct/updated after the move (including SNMPv3 username and passwd on both Controllers and AW), but I'm failing to see where the problem is. Airwave is reflecting the APs on each controller, but that's all.
    Anyone got an idea what I've missed?
    Thanks.
    Nathan
  • 2.  RE: Airwave not reporting traffic
    Posted May 09, 2023 07:29 AM
    A bit more of a dig yields
    https://community.arubanetworks.com/discussion/new-controller-on-airwave-no-clientusage-data
    https://community.arubanetworks.com/community-home/librarydocuments/viewdocument?DocumentKey=1f85df6d-88d5-4762-888e-8829247038ee&CommunityKey=96609c68-a98a-4a35-b790-987564d4402d&tab=librarydocuments
    The datapath session uses the controller's correct IP address (that of its management interface VLAN, shown correcty in ip interface brief) and the IP addresses configured in Airwave when checking for the controller IP address under 'Manage' for the controller device is also correct.
    I've run the qlog debug, but something I've not been able to view is the qlog output. When I enter 'vi amon' I get told '.....is not allowed.'
    Any thoughts that might help?
    Nathan
  • 3.  RE: Airwave not reporting traffic
    Posted May 15, 2023 11:52 AM
    I seem to be having very similar issues, recently abandoned our older AW server, and upgraded TWO NEW servers to the new AW 8.3.0 'redhat' version.  It appears all the devices (controllers and APs) seen in both AW servers, but I am not seeing any information on client devices.
  • 4.  RE: Airwave not reporting traffic
    Posted May 17, 2023 06:21 AM
    It looks like our problem was the result of a poor setting in AMP Setup>General>Performance
    Originally for this server the processes was set to 3. On our other 2 AW it is set to 15.
    This setting was generating errors on the System>Performance page (which I hadn't looked at, could have saved myself a lot of time here, no idea why/how it got set to 3)
    After this the server had to rebooted as it dropped and didn't recapture any data from the controllers. After a reboot, and giving some time for polling, we ended up with clients being reported and usage being recorded where previously we only saw '0'.
    We finally have Glass pretty much in line with the MC now, reporting almost accurately for each of the 3 clusters. I guess the variance with the MC is now down to Glass polling the AW instances.
    We still have problems with this AW server (link up link down 16386 alerts being generated) but clients and usage appears fixed.
    Nathan
  • 5.  RE: Airwave not reporting traffic
    Posted May 18, 2023 11:48 AM
    Thanks for the info, I have adjusted the settings to match yours in hopes this resolves the issues, if not I will most likely get a TAC engineer to go over it and find the error/missing config.
    Charles Zuber
    Lead Network Engineer – ECSE, CBRS:CPI
    Wayne State University
    Computing & Information Technology
    Wireless Network Engineering & Security
    5925 Woodward, RM 160
    Detroit, MI 48201
    PH: 313.577.2697
    FX: 313.577.5577
    EM: Zuber@wayne.edu
