Network Management
airwave not running after 7.5.6 update?!?
  • 1.  airwave not running after 7.5.6 update?!?
    Posted Oct 21, 2012 12:38 PM
    Console shows:
    ** Look out:: /etc/amp_disabled
    Current Version: RELEASE_7_5_6
    DISABLED - 2!!
    Any ideas?!?
  • 2.  RE: airwave not running after 7.5.6 update?!?
    Posted Oct 21, 2012 01:01 PM
    try "amp_enable" on the commandline
  • 3.  RE: airwave not running after 7.5.6 update?!?
    Posted Oct 21, 2012 03:23 PM
    You'll have to do one of the following:
    Pass the amp_enable command twice.
    or
    # amp_enable -now
    My concern is that the upgrade did not complete properly. May be worth opening a support case for a quick AMP health check. Check for crashes in your upgrade logs.
  • 4.  RE: airwave not running after 7.5.6 update?!?
    Posted Aug 09, 2013 11:38 AM
    Where can we find these upgrade logs?  Thanks.
  • 5.  RE: airwave not running after 7.5.6 update?!?
    Posted Aug 09, 2013 07:07 PM
    look in /var/log/upgrade
    should be a log file for each version you've done.
