Network Management
Airwave not showing SNR under RF Performance Charts
  • 1.  Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 11:36 AM
    I am trying to figure out why Airwave is not showing the SNR info under RF Performance.  Health and Speed are shown but SNR is not.
    I am using the default-amp profile on all Aruba controllers (ArubaOS 6.4.0.1) and Airwave 8.0.1.
    Any suggestions as to where to look for troubleshooting?
    Thanks!
  • 2.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 11:41 AM
    Is amon enabled under AMP Setup -> General ?
  • 3.  RE: Airwave not showing SNR under RF Performance Charts
    Do you have AMON enabled ? on both sides?
  • 4.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 11:43 AM
    AMON is enabled in Airwave.  I have also setup Airwave as the mgmt-server on the controllers using the default-amp profile.
  • 5.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 12:00 PM
    OK, I changed "Prefer AMON vs SNMP Polling" from Yes to No, and now I am getting the SNR info.  Not sure why that fixes things...
    There is no firewall stopping UDP 8211 traffic between Airwave and the controllers.  I am not sure what else would be stopping AMON from working correctly.
  • 6.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 12:01 PM
    Are you allowing 8211/UDP between controller and airwave ?
    Also checked if the information is getting send out:
    show mgmt-server message-counters process wms
    show mgmt-server message-counters process stm
  • 7.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 12:04 PM
    I have confirmed there is no firewall stopping PAPI traffic.
    I did check the mgmt-server counters before and they showed messages being passed as I would expect.
    Going to try upgrading AMP to the latest version and see if it makes a difference.
  • 8.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 12:08 PM
    That was going to be my next suggestion..
    Theres been a lot of bug fixes since 8.0.1
  • 9.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 12:13 PM
    you shouldn't have to do prefer AMON vs SNMP to make it work.
    As victor suggests, upgrade is your best course. I would then test without that option enabled and see if you are getting SNR results
  • 10.  RE: Airwave not showing SNR under RF Performance Charts
    Posted Jan 21, 2015 02:54 PM
    Upgrading to AMP 8.0.5 appears to have resolved the issue.
    Thanks for your help!
