Network Management
Airwave .ova install with disk >80GB?
  • 1.  Airwave .ova install with disk >80GB?
    MVP
    Posted Nov 27, 2017 09:31 AM
    Simple question for most I suppose but is is possible to configure the Airwave .ova aso it installs with more than the default 80GB diskspace?
    If so, what is the correct procedure? The install guide isn't even close to being clear about this..
  • 2.  RE: Airwave .ova install with disk >80GB?
    Posted Nov 28, 2017 01:58 PM
    There's a feature story that has yet to be implemented, but it used to be that when you increase disk, you have to run a few cmds to redo the partitioning.  In 8.2.4+, you need to open a TAC case for TAC to run the CLI cmds to help expand the disk.  Otherwise it's advised to install from the ISO since that will allow the install to take up the space allocated to the VM instance.
  • 3.  RE: Airwave .ova install with disk >80GB?
    MVP
    Posted Nov 30, 2017 05:03 AM
    .iso it is then. Thanks for the confirmation.
