Network Management
Airwave Problem
  • 1.  Airwave Problem
    Posted Mar 06, 2020 09:17 AM
    Hi
    I cannot log into the GUI or SSH to airwave. Does anyone experience the below error when SSH to airwave?
    Loading Menu...
    Unknown error: DBI connect('dbname=airwave','airwave',...) failed: could not connect to server: No such file or directory
    Is the server running locally and accepting
    connections on Unix domain socket "/tmp/.s.PGSQL.5432"? at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 891
    at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 905
    Mercury::DB::Q::_get_new_dbh('Mercury::DB::Q') called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 872
    Mercury::DB::Q::get_new_dbh('Mercury::DB::Q', undef, undef) called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 816
    Mercury::DB::Q::connect_to_db('Mercury::DB::Q') called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 809
    Mercury::DB::Q::dbh('Mercury::DB::Q') called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 406
    Mercury::DB::Q::_execute('Mercury::DB::Q', 'prepare', 'select version from seas_config where id = ?', 1) called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 389
    Mercury::DB::Q::execute('Mercury::DB::Q', 'select version from seas_config where id = ?', 1) called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 207
    Mercury::DB::Q::scalar('Mercury::DB::Q', 'select version from seas_config where id = ?', 1) called at /usr/local/airwave/lib/perl/Mercury/DB/SeasConfig.pm line 2414
    Mercury::DB::SeasConfig::field('Mercury::DB::SeasConfig', 'version') called at /usr/local/airwave/lib/perl/Mercury/DB/SeasConfig.pm line 2436
    Mercury::DB::SeasConfig::recent_field('Mercury::DB::SeasConfig', 'version') called at /usr/local/airwave/lib/perl/Mercury/Logger/AMPEvents.pm line 120
    Mercury::Logger::AMPEvents::amp_version('Mercury::Logger::AMPEvents') called at /usr/local/airwave/lib/perl/Mercury/Logger/AMPEvents.pm line 112
    Mercury::Logger::AMPEvents::cef_args('Mercury::Logger::AMPEvents', 'extensions', 'HASH(0x15c7770)', 'event_name', 'CLI user logged in', 'severity', 2, 'signature_id', 14, ...) called at /usr/local/airwave/lib/perl/Mercury/Logger/AMPEvents.pm line 95
    Mercury::Logger::AMPEvents::log_useraudit('Mercury::Logger::AMPEvents', 'msg', 'Logged in from 16:00', 'start_time', 6, 'user', 'admin', 'start_date', 'Mar', ...) called at /usr/local/airwave/lib/perl/Mercury/Logger/AMPEvents.pm line 130
    Mercury::Logger::AMPEvents::log_useraudit_cli('Mercury::Logger::AMPEvents', 'user', 'admin', 'start_time', 6, 'start_date', 'Mar', 'ses_key', 'm8UcSuGm0rKyaAiyrrfg4XYHhCQyPN6t', ...) called at /usr/local/airwave/lib/perl/Mercury/AMPCLI.pm line 56
    Mercury::AMPCLI::go('Mercury::AMPCLI', 'ampcli') called at /usr/local/airwave/bin/ampcli line 48
    main::__ANON__() called at /opt/airwave/local/lib/perl5/site_perl/5.10.1/Try/Tiny.pm line 76
    eval {...} called at /opt/airwave/local/lib/perl5/site_perl/5.10.1/Try/Tiny.pm line 67
    Try::Tiny::try('CODE(0x5745ab8)', 'Try::Tiny::Catch=REF(0x1642588)') called at /usr/local/airwave/bin/ampcli line 62
    main::go('ampcli') called at /usr/local/airwave/bin/ampcli line 67
  • 2.  RE: Airwave Problem
    Posted Mar 09, 2020 03:52 AM
    I would guess that the database stopped or got corrupted. What you could do is from the console (VM: use ESX/HyperV to access the console, Hardware: hook up monitor and keyboard to the appliance) and press the famous Ctrl-Alt-Del to trigger a system reboot. It might be that after the reboot the database will recover.
    If it doesn't, or if you don't feel comfortable doing that, please reach out to Aruba Support. This doesn't look like something to fix yourself.
  • 3.  RE: Airwave Problem
    Posted Mar 11, 2020 02:58 AM
    Thanks Herman. TAC will be looking into it today.
  • 4.  RE: Airwave Problem
    Posted Mar 09, 2020 11:57 AM
    Looks like disk might be 100% used and DB down. You have to contact TAC. They would have to use the linux rescue option to troubleshoot further.
    Also, as Herman stated sometime reboot gets the DB up for sometime. However, would be good to involve TAC during this so that we can create the support user if we are able to access and troubleshoot using it.
  • 5.  RE: Airwave Problem
    Posted Mar 11, 2020 02:57 AM
    Thanks for the info Vishnu. You are 100% correct on the disc usage of 100%. TAC will be looking into today.
