AirWave RAM usage - Kernel cache
  • 1.  AirWave RAM usage - Kernel cache
    Posted Apr 04, 2016 11:51 PM
    Hi all,
    I'm seeing the kernel cache is consuming high ram usage and the free memory is less than a gigs in average.
    Would it be safe for another 1000 new devices expansion or turning on VisualRF in future?
    Will Airwave free up the RAM from kernel cache for other processes and does it make any impact if kernel cache is using lesser RAM?
    thanks.
  • 2.  RE: AirWave RAM usage - Kernel cache
    Posted Apr 05, 2016 06:32 PM
    The status of "cached" for that memory is linux-speak for "ready to use as needed" (for the most part).
    You needn't worry about that parameter as your device-count grows.
  • 3.  RE: AirWave RAM usage - Kernel cache
    Posted Apr 05, 2016 10:15 PM
    so kernel cache is part of free memory right?
  • 4.  RE: AirWave RAM usage - Kernel cache
    Posted Apr 06, 2016 12:39 PM
    Effectively true - not technically "free" since the kernel has it, but that's true of all memory.
    It's a definition thing.
