Airwave RAPIDS on a Public WiFi
  • 1.  Airwave RAPIDS on a Public WiFi
    Posted Jan 03, 2018 02:47 PM
    Hi
    Should I turn off RAPIDS notifications on AIRWAVE if I am deploying Public WIFI in an outdoor enviroment?
    There will be lots of other Access points but due to this being a public deployment. We will have no control over these devices and they may be in the same are but they will not be on the LAN infrstructure.
    Scott
  • 2.  RE: Airwave RAPIDS on a Public WiFi
    Posted Jan 03, 2018 03:20 PM
    You could possibly setup a rule that detects an SSID with a similar name being discovered and use wildcards to cover a few different variations.
    If you are managing the switches in Airwave then you could also add a rule that if it is detected both on wired and wireless to trigger a classification.
  • 3.  RE: Airwave RAPIDS on a Public WiFi
    Posted Jan 09, 2018 06:38 PM
    That's totally up to you. You can modify the tirggers and RAPIDS rules to better match the environment, or disable if you want.
