Network Management
Airwave Report Extract
  • 1.  Airwave Report Extract
    Posted Feb 20, 2012 11:44 AM
    Due to the topology where our Airwave has been installed, we are unable to effectively export reports from the Airwave GUI.
    We do, however, have the ability to WinSCP onto the server and extract the files manually. Does anyone know if this is possible, or where the generated reports are located within the CENTOS file structure.
    Many thanks,
    Jason
  • 2.  RE: Airwave Report Extract
    Posted Feb 21, 2012 10:50 AM
    The report contents are stored in the database. You can export them from the user interface as CSV files (which could be scripted), and you can schedule the reports to be emailed to you. Otherwise, there's no other export format available.
