Network Management
Airwave Report permissions
  • 1.  Airwave Report permissions
    Posted Feb 18, 2014 09:27 PM
    Hi All,
    I'm trying to work out how i can make reports viewable from a read only user on Airwave.
    Currently the predefined reports are set all as per default and when i login as an admin i can see them.
    If i login as a read only user role, i can access the reports page but can't see any of the predefined reports.
    I have enabled and disabled the allow role based report visibilty however if i try and select subject based permissions i can't see any reports created by admin when i login as the read only user.
    As an admin user i can see the read only users reports but not the other way around.
    Is there any way i can publish report templates as an admin so that read only users can access the reports i want them to see?
    I'm using 7.7.9
  • 2.  RE: Airwave Report permissions
    Posted Feb 24, 2014 03:44 PM
    There's no way for non-admin users to see report definitions created by other users. However, if a report definition is created with Generated Report Visibility set to By Subject, then other users (including non-admins) will see generated reports whose subject matter (e.g. groups, folders, devices) they can see.
  • 3.  RE: Airwave Report permissions
    Posted Mar 02, 2014 09:55 PM
    thanks i didn't get far enough to check that. makes sense now!
