Network Management
Airwave Reporting
  • 1.  Airwave Reporting
    Posted Sep 12, 2016 11:52 PM
    Hi All
    Any idea how i can combine couple of reports into one?
    For example I want to combine CLIENT SESSION and NETWORK USAGE into One single report. Can this be done, if yes how please.
    Mahathma
  • 2.  RE: Airwave Reporting
    Posted Sep 13, 2016 04:38 AM
    You can create a "Custom" report Definition and just drag the parts you want onto your new "Custom" Report:
  • 3.  RE: Airwave Reporting
    Posted Mar 14, 2018 07:37 AM
    Hi Colin,
    There are mac-adrdresses at internal DB. I want to create a schedule; If a mac address inactive for 90 days, airwave alert to me. After this alert i want to delete this mac-address. How can i do that ?
    Best Regards
    Ersin
  • 4.  RE: Airwave Reporting
    Posted Mar 14, 2018 10:10 AM
    You mean client mac address? Airwave will automatically purge inactive clients based on client historical retention setting in AMp Setup >General>Historical Data Retention>Inactive Client and VPN User Data (0-1500 days, zero disables):
    Set this value to 90 days, airwave on 91st day during nighlty maintaince delete all old inactive clients from database.
  • 5.  RE: Airwave Reporting
    Posted Mar 14, 2018 10:40 AM
    @Pavan
    I believe he's asking about purging the controllers internal db.  Not the AMP database.
  • 6.  RE: Airwave Reporting
    Posted Mar 15, 2018 01:22 AM
    Hello Rob,
    Yes you are right, i want to purge inactive mac-address on the controller's internal db. What is your advice for that?
    Best Regards
  • 7.  RE: Airwave Reporting
    Posted Mar 15, 2018 02:59 AM
    The AirWave side doesn't currently process the internal db in a way to capture the 90 days of inactivity.  Let me ask around to see if there's a way to do it directly in the controller.
  • 8.  RE: Airwave Reporting
    Posted Mar 15, 2018 03:38 AM
    You cannot purge those values automatically.  You would have to remove them manually.
  • 9.  RE: Airwave Reporting
    Posted Mar 15, 2018 09:39 AM
    Hi Colin,
    How can i detect inactive users, can i take report ? Could you explain it please ?
    Best Regards
  • 10.  RE: Airwave Reporting
    Posted Mar 15, 2018 09:50 AM
    Active users and the internal database don't have a direct relationship.  What are you trying to do?
  • 11.  RE: Airwave Reporting
    AirWave holds a comparison template, so you'd need to constantly import the template to update for comparison to the next day.  This behavior doesn't trend for a 90 day inactive mac.  You'll need to file a feature request for this in the innovation portal.
