Network Management
Airwave reports
  • 1.  Airwave reports
    Posted Nov 04, 2013 02:43 PM
    I am trying to run reports through airwave. I want to exclude specific WAPs. I want to know if waht the syntax is for the exclude field in the reports.
  • 2.  RE: Airwave reports
    Posted Nov 04, 2013 03:14 PM
    You can run the report and specify either the Group / Folder or just one AP by excluding that one on the Exclude filter
  • 3.  RE: Airwave reports
    Posted Nov 04, 2013 04:20 PM
    what if i want multiple criteria
  • 4.  RE: Airwave reports
    Posted Nov 04, 2013 05:27 PM
    I'm a fan of the list all devices -> select modify devices wrench -> check the devices you want to report on (probably better if sorted by group/folder/location - something more effective than name) -> then run report.
    This lets you run a report against the selected devices, and lets you create any type of report, so if you want to run a custom report against those devices, you can.
  • 5.  RE: Airwave reports
    Posted Nov 19, 2013 09:46 AM
    Outstanding tip!  That's very helpful.
