Network Management
Airwave Reports Definition - change or create own customer definitions
  • 1.  Airwave Reports Definition - change or create own customer definitions
    Posted Feb 26, 2020 09:56 AM
    Hi there,
    we use Airwave 8.2.9.1 and have created customer reports.
    Unfortunately, we cannot select enough information about the ports when we create a report.
    We want to generate a report that reflects the last month. (Historical data)
    Under Customer Options we select "Ports Usage: Ports" and can only select the following:
    Name
    Port mode
    Device
    Alias
    MAC
    Used
    Description
    Traffic In
    Traffic out
    Max Traffic In
    Max traffic out
    But we also need the following in that selection so that the report can be used by us:
    Device location
    Port admin status
    Port Use PoE
    Port Speed
    Port Spanning Tree Status
    Is there a way to get this data for the report?
    TL;DR: We need more data fields from all switch ports to create a special report.
    Screenshots:
  • 2.  RE: Airwave Reports Definition - change or create own customer definitions
    Posted Feb 26, 2020 01:58 PM
    Hello Carstens,
    Except the Device location, we do not have an option to report this info in the reports as of today.
    Port admin status
    Port Use PoE
    Port Speed
    I would recommend you to file a feature request for the same @ innovate.arubanetworks.com
  • 3.  RE: Airwave Reports Definition - change or create own customer definitions
    Posted Feb 27, 2020 05:29 AM
    Hello Fayyaz Mohammed,
    You wrote: "Except the Device location, we do not have an option to report this info in the reports as of today."
    How can I get the information "Device location" in the report in the list of the Ports? I only get this information in the list of Devices (Switch). I also need this info in the list of ports ...
    I will make a feature request for the other information.
    regards
    Carstens
  • 4.  RE: Airwave Reports Definition - change or create own customer definitions
    Posted Feb 27, 2020 12:19 PM
    Device Location is based on Devices and is separate table not native to ports. Hence AirWave doesnt get the Location based on port basis. Please open feature request for this too. Other way is to manually merge the devices CSV file to Port CSV file (from reports) to get the data needed.
  • 5.  RE: Airwave Reports Definition - change or create own customer definitions
    Posted Mar 03, 2020 04:49 AM
    ok, I made a feature request:  https://innovate.arubanetworks.com/ideas/NMS-I-1654
  • 6.  RE: Airwave Reports Definition - change or create own customer definitions
    Posted Feb 27, 2020 02:28 PM
    Hi Carstens,
    Location is by default, present in the port usage report. if the location shows up in the monitor page of the switch on Airwave and if we have the "location" column selected in the report definition it will show that switch's location in this port usage report.  see attached report, i ran in my lab.
