Airwave return to support
  • 1.  Airwave return to support
    Posted Apr 05, 2016 04:45 AM
    Hi
    When I buy support for 1 year for Aiwave and am happy with the software release for several years so I dont renew support for a while. Let's assume after 3 years I want to get the new patches/software updates  - how should I return to support and how is it priced?
  • 2.  RE: Airwave return to support
    Posted Apr 05, 2016 08:50 AM
    In most cases to put something back under support, you have two options.
    1. You can backfill the missing years of support. So if you bought 1 year, then went three years without any support, on Year 5 if you need support, you would buy 4 years (3 of the previous and then one for the current year).
    2. You buy a new airwave license for the number of devices you need to match or exceed what you have.
    That is pretty standard across the industry, covering servers, networking, software, etc.
