Airwave set my controller to monitor only
  • 1.  Airwave set my controller to monitor only
    Posted Sep 07, 2020 06:12 AM
    Hello ,
    I am using Airwave and whenever i add my virtual controller (8.5 running as virtual mobility controller under ESX) the controller is added as monitor only and i can not change the option to Manage read/write
    What can be the issue?
  • 2.  RE: Airwave set my controller to monitor only
    MVP EXPERT
    Posted Sep 07, 2020 06:44 AM
    Are you able to post the Event and Alerts for the device in question after you have set it to Managed?
  • 3.  RE: Airwave set my controller to monitor only
    Posted Sep 07, 2020 08:14 AM
    It is expected behavior, MM and MDs setup can be monitor only, we can not manage in Airwave.
  • 4.  RE: Airwave set my controller to monitor only
    Posted Sep 07, 2020 09:22 AM
    So controllers can not be Managed/read write?
    What about pushing controller configs from AirWave  there is a full section named controller config where seems to have all options to set.
    I can not pull the configs from controller though , what is the catch here?
    Can i read WLAN/AP profile from Aruab? can use the controller config section to push config to controllers in a group? (they appear as monitor only as mentioned , can not be changed to managed)
  • 5.  RE: Airwave set my controller to monitor only
    Posted Sep 07, 2020 10:24 AM
    Aruba OS 8.X Mobility Master and Mobility Devices can not be managed by Airwave , all configuration need to be managed by MM only.
    Airwave Controller configuration UI is for Aruba OS 6.X series.
