Network Management
Airwave setup on Azure
  • 1.  Airwave setup on Azure
    Posted Jun 19, 2015 09:11 AM
    Good afternoon,
    I want to setup my Airwave server on MS Azure as a VM. I have managed to create the image and prep it for upload to Azure. After running the amp-install I get to setp 7 where I need to generate the AMP's SSL certificate, but get the following error:
    /etc/httpd/conf/ssl.key/server.key is not existing as (file)
    /etc/httpd/conf/ssl.crt is not existing as (directory)
    Can anyone assist?
  • 2.  RE: Airwave setup on Azure
    Posted Jun 21, 2015 06:18 AM
    as pointed out here: http://community.arubanetworks.com/t5/Aruba-Apps/AirWave-posts-should-be-made-to-Unified-Wired-amp-Wireless-board/td-p/238848 you better try that section.
    for your question, if you have a valid support contract, contact support and please do report back here.
