Network Management
Airwave shows inconsistent values in scheduled reports
  • 1.  Airwave shows inconsistent values in scheduled reports
    Posted Aug 21, 2014 09:09 PM
    Airwave 7.7.9 I'm trying to get a rolling 'previous month' report from Airwave. After experimenting a bit I found the Custom Reports and selected Client Inventory/Clients - it really does show me the data fields that I need. When I schedule this report to run daily I expect that this will duplicate some of the data in yesterdays report. Except it doesn't contain duplicate data - some entries get discarded each time this report runs - so that todays report contains less (historical) data than yesterdays! For example, if I have a report covering the period from 1 August to 30 August it will contain data about 15 August. If I then run the same report over the period 2 August 1 September it will still contain records describing 15 August. The two sets of records about 15 August are different, with the more recently generated set being smaller. I can see no other methods of extracting historical data other than specifying a report to active devices that are "Active during the report timeframe". Am I being over-enthusiastic here?
  • 2.  RE: Airwave shows inconsistent values in scheduled reports
    Posted Aug 21, 2014 09:38 PM
    SteveDowling,
    I would open a TAC case and have them examine your data retention settings to ensure nothing is getting discarded that you expect to be included.
  • 3.  RE: Airwave shows inconsistent values in scheduled reports
    Posted Aug 22, 2014 12:57 AM
    I'd be interested in the exact scheduling options used for this report.  Are you using specific time range: 'yesterday 8 am' to 'today 8 am' or are you setting just the date - yesterday to today.  In the 1st case, it will cover data that starts at exactly 8 am.  In the latter case, it's relative to when the report gets run which varies based on other reports and processes that take priority.
  • 4.  RE: Airwave shows inconsistent values in scheduled reports
    Posted Aug 22, 2014 01:12 AM
    The scheduling options are "a month ago" to "now". This generates a report that can be over thirty days long. At the moment, we're focussing on specific days within that thirty day period.
  • 5.  RE: Airwave shows inconsistent values in scheduled reports
    Posted Sep 08, 2014 05:01 AM
    All, I logged this case to Aruba TAC. It seems that this is a bad report to pull. The TAC recommend the pre-made report "Client Session". I guess we just do the post-processing...
