Network Management
Airwave switch HP 1700-24 status down
  • 1.  Airwave switch HP 1700-24 status down
    Posted Aug 10, 2018 11:12 AM
    I'm trying to register my HP procurve swith 1700-24 in my airwave server, it's correctly detected but the status stick to Down (SNMP get Failed).
    That's odd because all informations have been well retreived from my switch :
    - Neighbors tab is well filled
    - Interfaces are all there
    The only thing which is not retreive is the usage traffic.
    This status "Down" prevent it to be visible in "Topology" module.
    In the alerts & Event section : Failed to read device ressource data (received no data)
    I tried various device type (Router/switch, universal network, custom  ...) but each time there is a different problem (no lldp , snmp get failed, trzffci usage is there but no neighbors ...).
    Anybody else with this kind of problem ?
    Thanks in advance
    Olivier
  • 2.  RE: Airwave switch HP 1700-24 status down
    Posted Aug 13, 2018 12:07 PM
    The down status reports SNMP communication issue.  Have you tried following this article to test SNMP?
    What version of SNMP is in use?  Double check that it matches the Group -> Basic -> SNMP version setting.
  • 3.  RE: Airwave switch HP 1700-24 status down
    Posted Aug 14, 2018 04:55 AM
    I did the folowing check :
    $ sw2 100 sysname
    SNMPv2-MIB::sysName.0 = STRING: 1700 Entrepot3
    so the SNMP connection is ok.
    Sw2 100 .1 -Cc
    no timeout, saw the whole mib table.
    In the monitor screen
    Status : Down (SNMP get failed)
    Firmware unknow, no LAN MAC address, no usage, no uptime
    In the Neighbors tab, i call see all devices conencted to the switch
    In the Interfaces screen i can see all switch interfaces with incoming/outgoing traffic
    But status still Down !!!
    Olivier
  • 4.  RE: Airwave switch HP 1700-24 status down
    Posted Aug 14, 2018 11:28 AM
    Polling the device now doesn't correct the down status?  Check the SNMP fetcher logs from the System -> Status page, make sure there's no crashes/errors.
    Did you happen to try restarting the application from the bottom of the System page?  If not, give that a try when you can afford to have the AMP down for 10-15 minutes.
    If polling now and restarting the application doesn't resolve the issue, then it might be time to open a support case.
