Network Management
last person joined: 10 hours ago
Airwave switch's clients problem
  • 1.  Airwave switch's clients problem
    Posted Jun 06, 2017 10:57 AM
    Hi community,
    i have Airwave 8.2.3.1, which i added 1 AP discovered [aruba instant] and 2 switch manually (one is Zyxel and the other an Allied Telesis) with SNMP.
    All of them are up and good (not mismatched or something) but i see only AP's clients.
    Any ideas?
  • 2.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 11:02 AM
    Hi Fabio,
    Do you have any wired clients aswell? Does those clients listing in switch?
    Pavan
  • 3.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 11:07 AM
    I have at least 5 wired client online (on switch).
    Airwave don't see them on switch's monitor
  • 4.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 11:16 AM
    Could you try poll the swtich from Aps/Devices> monitor page and check the status?
    May I know the switch model/firmware version?
    If possible I  would recommand to upgrade the server to AMP 8.2.4 and check the status.
    Pavan
  • 5.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 11:24 AM
    Allied Telesis: AT-GS950/16
    firmware: AT-S79 V2.3.2 [1.1.1.94]
    Zyxel: GS1900-8HP
    firmware: V1.00(AAHI.0)
    Tried to poll, nothing change, polled 7/7.
    For upgrade AMP to 8.2.4 i'll put it this night on download, cause i can't saturate network now.
  • 6.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 11:39 AM
    What option you selected while adding the device manually from Device setup > Add page?
    Does Airwave reporting correct model and firmware version in APs/Devices>Monitor page. Checked supported device guide, i dont see support for this model/firmare in Airwave.
    I have attached latest AMP 8.2.4 supported guide.
    Pavan
    If my post addresses, your query give kudos:)
    Attachment(s)
  • 7.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 11:49 AM
    For adding them i done this:
    Device setup/Add/"router/switch"
    configured ip and snmp.
    It won't show name or other device info, but it shows usage and interfaces.
    I saw that they aren't in supported device, but i try to configured it and  Airwave shows monitoring of usage, maybe it only doesn't support clients?
  • 8.  RE: Airwave switch's clients problem
    Posted Jun 06, 2017 12:25 PM
    Airwave proivde limited montioring support for device which does not have support. You could try upgrade the server to AMP 8.2.4 and check but not sure it will list wired clients.
    I would recommand to file feature request at Aruba support site and follow up with your accounts team.
    Pavan
  • 9.  RE: Airwave switch's clients problem
    Posted Jun 07, 2017 02:19 AM
    I'll do a file to feature request at Aruba support.
    Thanks Pavan for support
