Network Management
AirWave Template mismatch in Aruba Instant VC for cp-logo-checksum
  • 1.  AirWave Template mismatch in Aruba Instant VC for cp-logo-checksum
    Posted Oct 18, 2016 04:05 PM
    Hi All,
    I have a template mismatch that I can't seem to get rid of. It's always the cp-logo-checksum. I have fetched the new template from the IAP VC multiple times and applied all changes but the mismatch always appears.
    I have also verified that the the:
    • captive_portal_cert_checksum
    • captive_portal_logo_checksum
    variables are all correctly in the template.
    Has anyone seen this before?
    N
  • 2.  RE: AirWave Template mismatch in Aruba Instant VC for cp-logo-checksum
    Posted Oct 20, 2016 11:26 AM
    The captive logo config is controlled at group level and not per VC/AP level. Thus, we need to go to Group->Basic page to select the captive portal logo image that we want to use. The image needs to be
    pre-uploaded to AMP in 'Device Setup'->'Upload Firmware & Files'->'Captive Portal Logo Files'. Also, please make sure the image is less than 16k.
    Vishnu
  • 3.  RE: AirWave Template mismatch in Aruba Instant VC for cp-logo-checksum
    Posted Nov 15, 2016 02:38 PM
    Finally getting back to this. This worked perfectly. Thank you.
