Airwave Templates and variables
  • 1.  Airwave Templates and variables
    Posted Nov 13, 2014 11:51 AM
    Greetings,
    I am configuring a new template and want to set the avaiable bandwidth for an SSID.
    I had hoped to use custom variables similar to
     %if custom_variable_4%
     bandwidth-limit %custom_variable_4%
     %endif%
    What i would like to do is use an "Elseif" after the bandwidth-limit command to set the default when custom_variable-4 isnt present.
    I have tried
     %elseif%
      bandwidth-limit 1024
      %endif%
    When I push the config to the AP/VC and audit it, it fails.
    Is there a command similar to "else" that will allow me to apply a default if the chosen variable is empty?
    TIA
    G
