Network Management
Airwave threshold in performance graphs
  • 1.  Airwave threshold in performance graphs
    Posted Oct 21, 2017 12:07 AM
    Hi community:
    Where can I find the thresholds in every graph of performance Airwave physical server? I bought an AW-HWDL360-ENT pre-installed hardware
    Regards
    Karlink
  • 2.  RE: Airwave threshold in performance graphs
    Posted Oct 23, 2017 01:36 PM
    Not sure I'm understanding your question properly.  The benchmarks for the Enterprise box are based on simulation data, so real world values will fluctuate based on deployment variables.  If you AMP is processing slow or falling behind, then a support case should be opened to have support look at fine tuning the performance variables (or you can experiment with the variables - they are on AMP Setup -> General Tab -> under the Performance dropdown).
