Airwave unmanage IAP
  • 1.  Airwave unmanage IAP
    Posted Apr 04, 2016 11:22 AM
    We have IAP's in Airwave we don't want to be managed, we've tried unchecking a couple options but haven't figured out how to allow management from the local IAP GUI and stay in monitoring in Airwave.
    Options we tried on the IAP VC and Group for the particular VC in Airwave:
    Aruba GUI Config - Yes
    Enable Instant GUI Config - Yes
  • 2.  RE: Airwave unmanage IAP
    Posted Apr 04, 2016 11:41 AM
    You should set "Manage local configuration on controllers" to NO.
  • 3.  RE: Airwave unmanage IAP
    Posted Apr 04, 2016 12:39 PM
    We already have that set to NO and still can't manage them locally.
    Manage local configuration on controllers:
    This option enables/disables the management of local configuration including audit, push and import operations
  • 4.  RE: Airwave unmanage IAP
    Posted Apr 04, 2016 01:56 PM
    Are you sure the IAPs are in the group you are editing? Did you save and apply changes from Airwave?
  • 5.  RE: Airwave unmanage IAP
    Posted Apr 04, 2016 03:05 PM
    100% sure IAP's are in the group for the location and hit save/apply. If we toggle Manage local configuration on controllers from No to Yes and back to No it says " There are no changes to be applied."
  • 6.  RE: Airwave unmanage IAP
    Posted Apr 04, 2016 03:09 PM
    Manage should be Off.  IGC should be Off.
    what version of Airwave and what version of Instant AP?
  • 7.  RE: Airwave unmanage IAP
    Posted Apr 04, 2016 03:30 PM
    Looks like turning off IGC allowed for management locally. Thanks!
