Network Management
Airwave update CentOs
  • 1.  Airwave update CentOs
    Posted Jun 24, 2014 04:55 PM
    Airwave 8 come with a CentoOS 6.2. There is a problem if I execute a "yum update" to update to CentOS 6.5?
    We use Hyper-V as hypervisor and CentOS 6.4 and newer are best compatible with this (kernel patchs).
    This is indicated by Aruba?
    Paulo Raponi
  • 2.  RE: Airwave update CentOs
    Posted Jun 24, 2014 06:29 PM
    You can certainly try it on your own, but it likely won't be supported if you have/find issues. At some point AirWave will be upgraded to deploy CentOS 6.4, or later, but there's not a supported reason to update. All major security vulnerabilities are patched in/back ported as part of the normal upgrade process (like most all Linux-based OS servers). Loads of time is spent on QA, rapid and early OS upgrades are not tenable long-term.
