I've just downloaded the Airwave upgrade package for vsn 7.7.4. We were running 7.7_BETA_F before I downloaded the package.
Unpacked the tar file into /usr/local/src/upgrade.
Sadly there didn't seem to be any documentation as to what to do next. Typed make and lots of things started to happen. Unfortunately the upgrade seemd to sail with an error 2 as it couldn't find a particular http package.
There is now a file in /etc called amp_disabled and whatever command I type in at a shell prompt, although it seems to work has "DISABLED - 1!!" appearing at the end.
How was I supposed to install the update?
Will deleting /etc/amp_disabled start things up again?
Rgds
Alex
