Network Management
Airwave upgrade to 8.0
  • 1.  Airwave upgrade to 8.0
    Posted Jun 23, 2014 07:46 AM
    I'm currently running airwave 7.7.6, can I upgrade to 8.0 from 7.7.6 ??,
    if yes, are there some consideration I can take care with??
    Thank you
  • 2.  RE: Airwave upgrade to 8.0
    Posted Jun 23, 2014 08:14 AM
    You can.  It is sort of hidden in the release notes:
    "Note that updates are only supported from up to two versions prior. Contact support if you are upgrading from three versions prior or more (for example, from 7.4 to 7.7). "
