Network Management
Airwave uprade to 8.0.0 -- VisualRF issues
  • 1.  Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 10, 2014 02:08 PM
    It's great that flash if gone, my boss likes looking at floorplans on his iPad.
    We notice however that the heatmaps got a LOT cooler in the new version (poorer coverage, not The Fonz)
    We've been using VisualRF to plan a new store deployment and have been hitting the mark pretty squarely each time. The store which we were finalizing yesterday now looks terrible.
    I can't find any assumptions or settings in the system which were changed, but predicted coverage dropped terribly.
    What's changed? and how do I change it back?
    Plan yesterday afternoon (flash-app):
    Plan this morning (html5-app):
  • 2.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 11, 2014 05:25 AM
    Msabin,
    Is this pre-deployment?  Please screenshot your settings on both.
  • 3.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 11, 2014 07:07 AM
    Have you tried measuring the floor again?
  • 4.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 11, 2014 12:28 PM
    This floorplan is all planned APs in pre-deployment planning.
    I re-measured the floorplan which changed nothing.
    Here are the floor and AP properties we use for our planning, I can't show the former screenshots since we've upgraded and can't go back easily, but they are the same assumptions we've used for 60 or so stores.
  • 5.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 12, 2014 05:14 PM
    I have further tried restarting VisualRF and switching back to flash.
    Now live floorplans looks pretty similar to prior, but planned floorplans still look terrible (in both html5 and flash)
    I've got a ticket open with TAC, unless anyone has any more ideas, I'll just wait on TAC and report back what I learn.
  • 6.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 18, 2014 02:48 PM
    I just upgraded from 7.7.11 to 8.0.0 and I'm seeing the same issue.   DWG imports don't load a floor plan in HTML5 mode and in Flash no layers are showing up to unselect unneeded layers from our facilities master floor plan files.
  • 7.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 18, 2014 04:27 PM
    Seems as though I am suffering from the "cooling" issue as well.
    I'll dig deeper into this and see if I can find anything.
  • 8.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 18, 2014 04:31 PM
    TAC has been able to reproduce the problem, and is processing it as a bug.
    I'll keep you posted as the ticket proceeds...
  • 9.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 18, 2014 05:02 PM
    amazing.
    if you get BUG ID, can you share so if I open a case ill refer to it to get more eyes on it.
  • 10.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 18, 2014 05:28 PM
    Ditto, I am experiencing the same issue, so i will call in and let them know more people are seeing the problem if you can get an bug ID.   So far i am liking 8.0, just got to get things fixed.
  • 11.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jun 19, 2014 12:09 PM
    We may have worked out the issue.
    If you planned an AP in 7.x and upgraded: the planned AP looks terrible.
    If you plan an AP in 8.x after upgrade: the planned AP looks great.
    We've got 20 or so planned sites - 250 or so planned APs - to re-plan, but the plan seems to be fine if it is done in the new rev.
    I have asked TAC to try to get the problem fixed to save folks who haven't upgraded yet some extra work.
  • 12.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jul 24, 2014 08:20 AM
    Has TAC been keeping you up to date on getting the issue fixed?  Having the problem in 8.0.1.
  • 13.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jul 24, 2014 01:06 PM
    As far as planned in 7.7 and upgraded to 8.0 failing to correctly model, TAC (or rather Engineering) has decided that this doesn't merit attention. We had 16 stores' wireless plans in progress and have a lot of work to re-plan them, so I've complained at some lenght, but I'm not really expecting them to try to resolve this.
  • 14.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jul 24, 2014 01:09 PM
    I think that means its time for the rest of us who are experiencing this to call in then, because it does not seem like an acceptable answer that i have to redo all my plans.
  • 15.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jul 24, 2014 01:20 PM
    My case number if it helps anyone:
    1547369
  • 16.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Jul 24, 2014 02:19 PM
    Same problem here reported. Aruba Support acknowledged it as a defect but workaround to turn HTML off in the setup setting.
    Defect number: DE19138
  • 17.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Nov 21, 2014 07:41 AM
    Update on this issue. I believe the issue is resolved in version 8.0.5
  • 18.  RE: Airwave uprade to 8.0.0 -- VisualRF issues
    Posted Nov 28, 2014 07:53 PM
    I also think it's been fixed in 8.0.5 - kind of forgot I was testing it.
