Network Management
Airwave user error visualrf
  • 1.  Airwave user error visualrf
    Posted Mar 19, 2014 01:45 AM
    Hi all,
    I've got an installation of AMP 7.7.8 and when i browse the visualrf maps i see a lot of users with a yellow alert and the following error:
    discovering AP undefined for client user@example.com not found on floor
    what exactly does this mean? I'm guessing it has something to do with the user no longer being associated?
    Scott
  • 2.  RE: Airwave user error visualrf
    Posted Mar 19, 2014 02:20 AM
    I believe you may be seeing this if...
    The client device is attached to a particular AP which is not on the map you are looking at. The reason the client icon actually appears on the map, is because other APs that are on this map can "hear" the same client device. Therefore, Airwave is showing you the client is potentially "nearby".
  • 3.  RE: Airwave user error visualrf
    Posted Mar 19, 2014 08:24 PM
    thanks, that makes sense.
