Airwave Version 8.2.5 Add manuall devices
  • 1.  Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 09:47 AM
    Hello all,
    we have recentaly upgraded Airwave to the version 8.2.5. Now I can't find anymore where to add manually devices!
    In the previous version was this possible under "Device Setup":
    But on the version 8.2.5 I cannot find this point anymore!
    Also in the latest user guide provided in airwave I can't find the answer.
    Can anybody help?
    Many thanks in advanced.
  • 2.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 10:05 AM
    From the "select the type of device to add" dropdown list, can you select custom?
  • 3.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 10:42 AM
    Hi James,
    as you can see in the second foto in my first mail or also below is this no more available under "Device Setup". Here again the foto from the version 8.2.5.
    jp
  • 4.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 10:47 AM
    Maybe I wasn't clear. Click on the arrow on the drop down list as highlisted below. Then select custom device.
  • 5.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 11:37 AM
    James,
    the point is that you have a Airwave version before 8.2.5! You have under the "Device Setup" drop down menu the following items:
    But we have the version 8.2.5 and we cannot find the "add" item under "Device Setup" and this is the point.
    Cheers,
    jp
  • 6.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 11:41 AM
    It's there in 8.2.5, try to flush your browser cache or go into incognito mode in the browser. Also make sure your account is an admin account. :)
  • 7.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 12:40 PM
    Thanks for your replay.
    I'm logged in with the "admin" account. ;) I have also try to enabled the incognito mode with Firefox version 56.02 and with Safari version 10.1.2 and also with Google Chrome version 62.0.3202.75 same results no "add" item under "Device Setup"?
    By the way when I go to the version 8.2.4.1 then I get the "add" item...
    jp
  • 8.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 27, 2017 04:53 PM
    Is there a license key added on this setup?  If you're at the max for your license key, then the 'add' setting is hidden.  Check Home -> License to see whether or not you're at the limit.
  • 9.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Oct 30, 2017 02:48 AM
    Hi Rob,
    you are right it is was a license issue.
    Many Thanks,
    jp
  • 10.  RE: Airwave Version 8.2.5 Add manuall devices
    Posted Jun 06, 2019 11:54 AM
    Hi Rob,
    Could we get this added to the documentation pdf, I just spent about an hour and a half going through various search results before finding this thread.
    Thanks!
