Network Management
Airwave Visual RF site map does not display
  • 1.  Airwave Visual RF site map does not display
    Posted Jul 24, 2014 04:51 AM
    Hello all I have a very perculiar problem with the visual RF maps. Which only just started (everything was working as expected).
    From the global map I can not drill down into any site/uilding/floor level map.
    Clicking on any of the site maps (from the global map) just refreshes/re-displays the main global map?!
    Im using IE9 with Java7.6.
    Does anyone have any sggestions?
    Thank you,
    Red.
  • 2.  RE: Airwave Visual RF site map does not display
    Posted Jul 24, 2014 06:56 AM
    Just curious. Have you tried to access it from another browser?
  • 3.  RE: Airwave Visual RF site map does not display
    Posted Jul 24, 2014 08:14 AM
    Hi Jamie,
    Yes Firefox with the same effect :(
  • 4.  RE: Airwave Visual RF site map does not display
    Posted Jul 24, 2014 08:45 AM
    Have you tried cleaning out the cache? Sometimes wierd cache problems result in odd encounters.
  • 5.  RE: Airwave Visual RF site map does not display
    Posted Jul 24, 2014 12:02 PM
    What version of AMP are you using?
    I am on AMP AMP 8.0.1 using the new HTML5 interface, and the only problem I run into sometimes is when I load a floorplan it comes in blank, but it seems to be only certain PDFs that it happens to over and over.
  • 6.  RE: Airwave Visual RF site map does not display
    Posted Jul 26, 2014 11:16 AM
    Hi. Are you loading floorplans as pdfs or something else?
  • 7.  RE: Airwave Visual RF site map does not display
    Posted Jul 28, 2014 07:47 AM
    Hello All,
    Thankyou for your replies. It seems the server has thrown a wheel and needs a rebuild.
    Will update once this has been done.
    Red.
