AirWave VisualRF floor plan issue
  • 1.  AirWave VisualRF floor plan issue
    Posted Oct 08, 2015 08:58 AM
    Hello all.
    I've been uploading some floor plans onto Airwave's VisualRF feature and come across a weird issue with a couple of sites.
    When adding the deployed APs to the floor plan all I get is a big red and yellow half and half band on the heatmap feature. I've attached a screen grab of this... anyone ever see this or know of the cause/fix?
    Thanks in advance
    Danny
  • 2.  RE: AirWave VisualRF floor plan issue
    Posted Oct 08, 2015 09:16 AM
    I assume you are scaling the drawings correctly? I usually see heatmaps like that when floorplans are not to scale.
  • 3.  RE: AirWave VisualRF floor plan issue
    Posted Oct 08, 2015 09:53 AM
    Yep, the drawing was to scale. What I did forget to mention was this site had iAP 93's and the heat map for that was fine. They then had iAP 205's installed so I removed the old floor plan and added the new one (same scale) but with the 205's in there new positions... I also had another site do the same with 93 -> 205 upgrades.
    Danny
    Sr. Network Engineer, ACMP, ACCP
