Network Management
Airwave VM Size requirements
  • 1.  Airwave VM Size requirements
    Posted Jan 07, 2015 05:37 PM
    Looking for design requirements for Airwave in a VM deployment.  Looking at 2,000 to 2,500 hardware devices with average client count upwards of 3,000 to 5,000 clients at any given time.
    VM guldlines for memeory requirements, processors, etc...
    Thanks in advance...
    Cheers,
    David Z.
  • 2.  RE: Airwave VM Size requirements
    Posted Jan 07, 2015 05:43 PM
    Take a look at the AirWave sizing guide:
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14101
    You likely want to spec similar to the AW-HW-ENT
  • 3.  RE: Airwave VM Size requirements
    Posted Jan 07, 2015 06:01 PM
    Thank you for the document....
  • 4.  RE: Airwave VM Size requirements
    Posted Jan 08, 2015 09:34 AM
    dzeising,
    Please keep in mind that Airwave is disk I/O intensive so make sure to provision 20% above what Tim is recommending, my personal experience with Airwave's running on a VM have not been good.
    Most likely because whoever provisioned them didn't know how to configure VMWare properly.
    The sizing guide unfortunately does not take into account number of clients and how much data will Airwave will be seeing, it is based of number of devices.
  • 5.  RE: Airwave VM Size requirements
    Posted May 20, 2015 04:56 PM
    How do you handle/adjust sizing if the total client count is 500 for example. The sizing guide specifies either "1500" or "4000". Do I just divide the hard disk space and memory...then add the 20% because it will run on a VM?
  • 6.  RE: Airwave VM Size requirements
    Posted May 20, 2015 04:57 PM
  • 7.  RE: Airwave VM Size requirements
    Posted May 20, 2015 04:59 PM
    Perfect...thank you!
  • 8.  RE: Airwave VM Size requirements
    Posted Aug 23, 2017 12:34 PM
    Hi guys,
    I have used the AirWave Server Sizing Calculator at https://ase.arubanetworks.com/solutions/id/77 and these are the values for a virtualized environment:
    Your AirWave server recommended sizing:
    * Recommended CPU PassMark score is 6271
    * Recommended memory is 7GB
    * Recommended disk IOPS capacity is 1374
    * Recommended disk space is 110GB
    However, it doesn't show number of CPUs or number of cores. Do I have to assume is 1 CPU with 1 core?
  • 9.  RE: Airwave VM Size requirements
    Posted Aug 25, 2017 11:00 AM
    Hi guys,
    Any idea?
