Network Management
Airwave vVM sizing guide for 8.2.10
  • 1.  Airwave vVM sizing guide for 8.2.10
    Posted Feb 19, 2020 10:44 AM
    Hello
    I see that in the sizing guide they aruba recommends  for 750 devices 8 Cores, 48GB ram 500GB storage
    But what about if the client has airwave but just got like 30 AP.   How much it will need? where can i find a document that it says how many you need if you got less than 100 devices or something like that at least or 50 devices
    Cheers
    Carlos
  • 2.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 19, 2020 11:04 AM
    You can use the OVA image and deploy the server. The OVA will have the specs till 100 devices. Below is a screen shot from installation guide.
  • 3.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 19, 2020 11:12 AM
    Vishnu, thank you very much
    This help me in a few deployments we got that wants airwave.
    I got one case, they have around 400 devices
    Thats almost  half the devices of the server sizing guide
    What about that case?
  • 4.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 19, 2020 11:19 AM
    For the 500 device count i would recommend going with the sizing for 750(thats the least sizing).
    Also, since its VM we need to allocate 20% more than what is recommended in guide. So, choosing 750 sizing for 500 would be good.
  • 5.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 20, 2020 09:52 AM
    Okay
    Can someone verify me this info? my Server which has ESix is really old and is almost out of resources... i deployed the machine but of course is does not turn on
    I could see this on the resources
    32GB ram
    1 core?
    128GB HD?
    those are the real values for this  OVF template?
    I dont know too much of Vmware just a little to deploy virtual machines so have me some patience please
  • 6.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 20, 2020 10:52 AM
    Increase number of cores to 6 and try load the machine.
  • 7.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 20, 2020 10:55 AM
    Mine does not have  6 cores
    what i just need to know is the requirements of the template, so i can tell the client this is what we need
    Pavan
    The requirement will be
    6 CORES
    32GB ram
    128GB HD
    Is that correct Pavan? i mean for that OVF for 100  devices.
  • 8.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 20, 2020 11:22 AM
    How many devices are you planning to monitor/manage using Airwave, if it is fpr 100 devices then number of cores recommended is 6 and disk space size is depend on historical retention values we set in Airwave better set to 250GB , RAM memory is more than enough.
    If server is for production deployment try use Airwave ISO image to install server, OVA files is for POCs and it is optimized to monitor only 100 devices, in future if you are planning to add more devices then OVA installed server will have performances issues.
  • 9.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 20, 2020 12:46 PM
    Hello Pavan
    I would like to know the recommended resources i need for 40 devices in production, the retention would be like 1 year if its possible.
    I have no information of Aruba that says less than 750.   Or at least in the sizing guide it does not says.
    Can you help?
  • 10.  RE: Airwave vVM sizing guide for 8.2.10
    Posted Feb 20, 2020 01:57 PM
    For 40 devices.
    CPU cores 6
    RAM memory 15GB
    Disk space 200. To 250GB
    Still you need to use ISO image to install production server.
