Network Management
Airwave won't finish install : error how?
  • 1.  Airwave won't finish install : error how?
    Posted Oct 26, 2016 03:05 AM
    HI there, as attached screenshot shows,
    errors occur after 'restarting daemons and Re-initializing database:
    What is going wrong?
  • 2.  RE: Airwave won't finish install : error how?
    Posted Oct 26, 2016 04:27 AM
    What kind of system are you installing Airwave on? If that is a very recent server, make sure you have the most recent Airwave installation ISO (version  8.2.2.1 at the moment). The errors on the i915 'render error' do indicate some issue with compatibility with your server.
    If you already used the latest installer, you might need some specific drivers for your system. Please contact your partner or Aruba TAC for support on this installation.
