Network Management
AirWave wont verify configuration on switches
  • 1.  AirWave wont verify configuration on switches
    Posted Jun 10, 2019 03:34 PM
    I currently use AirWave to manage about 500 IAPs. I am now looking into using it to manage switch configuration/firmware and have added a few switches to test. I added HP2530-8P and HP2530-24P groups and folders. I then added a test switch with our standard configuration using the "amp-server" command and used it's config to make a template for each group. Only 1 of the 6 I have tried adding after the initial switch will actually verify the configuration. They check-in with AirWave but just stay as "Unknown" for the configuration.
    I see that the switches themselves often have logs showing the AirWave server entering an incorrect username/password despite all our switches having the same login credentials. The AirWave server log shows that the SSH timed out. I have upped the SSH timeout setting in AirWave to the max 120 seconds and still nothing.
    There are slight revision differences between the switches (part of why I am adding them) so I found other switches with the same version as the working ones and was still not able get the ssh connected. I changed the default SSH credentials for Aruba Switches in Device Setup > Communication and re-added deleted/re-added the switches. Still nothing.
    I see on the successful switches that the AirWave system logs in, and enters the following commands:
    console local-terminal none
    session interactive-mode disable
    terminal width 1920
    include-credentials
    Any ideas as to what is going wrong here?
  • 2.  RE: AirWave wont verify configuration on switches
    Posted Jun 10, 2019 05:29 PM
    what is the version number that is working and not working? if amp itself is unable to ssh to the switch, are the ssh creds same for all the switches or could they be different? could you manaully try ssh into the switch using putty or some other ssh client, check if the login credentials work? once confirmed, update the same creds on the manage page of this switch in question on Airwave?
  • 3.  RE: AirWave wont verify configuration on switches
    Posted Jun 11, 2019 09:43 AM
    Thanks for the reply. Both working switches are on YA.16.05.0008 but there are other switches on the same version that don't work. I can SSH to the device with the same credentials, and can also SSH to the device from AirWave if I do it manually from the Monitor page. All our 2530 switches have the same credentials and I have logged into all the ones I have tried to load.
  • 4.  RE: AirWave wont verify configuration on switches
    Posted Jun 11, 2019 12:46 PM
    Seems like the issue stemmed from the banner we had. That was the only difference I could find between working and non-working. The working ones had no banner. Once I removed the banner they seemed to load fine. I think it was because we used the '%' symbol as our delimiter which is the same as the variables in the configuration. Not sure why that would cause an SSH issue, I would think it would still be able to successfully login.
  • 5.  RE: AirWave wont verify configuration on switches
    Posted Jun 17, 2019 10:51 AM
    Hi , what is Airwave version ? Yes we had issues in getting configuration if banner is set. And we have fixed that issue in 8.2.9.0 release. Could you please upgrade your Airwave and provide the feedback
  • 6.  RE: AirWave wont verify configuration on switches
    Posted Oct 15, 2019 12:30 PM
    we have the same issue, and we are on version 8.2.9.1
  • 7.  RE: AirWave wont verify configuration on switches
    Posted Oct 15, 2019 12:50 PM
    MOTD banner issue on switch is actually fixed in Airwave 8.2.10 version. For Airwave 8.2.9, there's apatch to fix the issue. Please work with TAC for the patch to be applied on the server or upgrade to 8.2.10 which has the fix.
