AirWave + XML Authentication
  • 1.  AirWave + XML Authentication
    Posted Jan 06, 2015 11:33 AM
    I'm trying to tap into Airwave data from a different server. I looked into most of the links on this forum but I still have questions. My questions are:
    1- Is Curl and PHP the ONLY way to tap into the data from outside the server?
    2- Can the data be tapped into directly using SQL for example?
    3- If Curl is the only way to tap into the data, do I have to give myself privileges on the Aruba server so that I can be authenticated from a different server?
    4- Does my server need to have php installed as well as Curl, or is Curl enough?
    I appreciate any guidance or tips.
  • 2.  RE: AirWave + XML Authentication
    Posted Jan 06, 2015 11:42 AM
    Yes you can access the database directly, you will need to adjust the postgres database to allow outside connections.
  • 3.  RE: AirWave + XML Authentication
    Posted Jan 06, 2015 11:49 AM
    So SQL can access Postgres if Postgres is adjuted to allow outside database?
    If so, where can Postgress be  adjusted to allow outside connections? Thank you.
  • 4.  RE: AirWave + XML Authentication
    Posted Jan 06, 2015 02:52 PM
    Usually a file is modified to allow outside hosts to connect to the database.
    see
    http://www.postgresql.org/docs/9.1/static/auth-pg-hba-conf.html
