Network Management
Airwave Zero Clients on AP Report
  • 1.  Airwave Zero Clients on AP Report
    Posted Aug 28, 2018 03:52 PM
    Hi Guys,
    We have recently had a few issues with bad AP’s not accepting connections from clients, the Instant AP’s are monitored by Airwave but appear online as if there was no issue.
    When looking under clients on one of the bad AP’s in Airwave its clear from the graph it’s had no clients in the past week which indicates an issue.
    Question is, can we report or alert on Airwave for AP’s which have had zero clients in the last 7 days?
  • 2.  RE: Airwave Zero Clients on AP Report
    MVP EXPERT
    Posted Aug 29, 2018 03:51 AM
    You might be able to achieve this using an "AP Usage" Trigger. So Alert if AP Usage >= (Kbps) for Duration of X? Or there is the Client Count trigger as well. Unfortunately I do not have access to an AirWave server at the moment to be 100% certain. You can add the Triggers via System > Triggers > Add
