airwave zero out free drive space
  • 1.  airwave zero out free drive space
    Posted Apr 21, 2020 01:45 PM
    Hi , I was wondering if there is a way to zero out un used space for the Drive airwave is using , This is a VM deployment and we are trying to re-allocate drive space that isnt being used.
    Thank you
    Pino
  • 2.  RE: airwave zero out free drive space
    MVP EXPERT
    Posted Apr 21, 2020 04:16 PM
    Hi Pino,
    You login with SSH account "ampadmin" you can remove some old files.
    Also read the Airwave Server Sizing Guide for the right sizing:
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=38542
    For VMware 500GB should be recommended to max. 750 airwave devices.
    Disk expension can be done but i will advise you to work with TAC support for doing that.
    Or..... Create and export a backup, install a new virtual server and put the backup back. That is most likely the fasted method.
    One more thing: Start with version 8.2.10.1 the operating system is upgrades from CentOS6 to CentOS7, to get into CentOS7 a re-installation is also required.
    Only put a backup back from the same version!
  • 3.  RE: airwave zero out free drive space
    MVP EXPERT
    Posted Apr 21, 2020 04:18 PM
