Network Management
Airwave ztp aruba switch
  • 1.  Airwave ztp aruba switch
    Posted Sep 03, 2018 08:39 AM
    Hi.
    Im about to use airwave to do ztp on our aruba 2930f switch, it works fine, but when i enable snmpv3, and airwave tries to poll data, i get an error in the debug
    " SNMP mSnmpCtrl:SrDoSnmp: SR_USM_UNKNOWN_ENGINE_IDS"
    i can see the snmpv3 engine id is a aruba tag and the mac address of the switch, but not a mac address i can find, can i change that? when i try im getting a "Action is ignored in user mode"
    everything else works fin but after the ztp airwave reports the switch down because of the snmp error.
    in the ztp template i use the variable snmpv3 engineid "%snmpv3_engineid%"
  • 2.  RE: Airwave ztp aruba switch
    Posted Sep 04, 2018 12:39 PM
    It might be that the group is still trying to use SNMPv2 which is the default.  Check the Group -> select group -> Basic.  Make sure the setting for the device type is using SNMPv3.
  • 3.  RE: Airwave ztp aruba switch
    Posted Sep 06, 2018 09:29 AM
    hi.
    the group is in snmpv3, turned it back to snmpv2c again until i figure up why there's an error.
